As it stands now it has.
Navman gps
Lightforce 240 XGT's
GME 3200 UHF
Traxide tronics dual battery system
80lt engel fridge/freezer with dual zone top (top fridge and bottom is the freezer)
Allied Wasp 16x8 rims (x6)
315/75/16 goodyear MTR's
normal recovery gear (snatch strap, drag chain, rated schackels, gloves)
Air comp
Rihno roof racks
Things left to do
Turbo and intercooler
3" exaust
Rear roll bar
Rear step (i will make both roll bar and step)
And maybe a front locker.
And here is the latest pic, i will try and get some action shoots on the weekend.
Hope you all enjoyed my build up
It has taken about 12 months to get it to where it is now.
Some factory specs for this model.
Manufacturer's specifications
station wagon, 6 seats, 4 doors, front outer seatbelt pretensioners, ABS brakes available
loa: 4890mm, width: 1940mm, height: 1920mm track: 1605mm/1600mm (standard, RV), grnd clearance: 230mm (standard, RV
approach: 31-36, departure: 24-27, ramp break over: 155-151
weight: 2230kg-2405kg (unladen), GVM: 3180kg-3260kg, towing: 750kg (unbraked) to 3500kg (braked, regulations permitting
6-cyl diesel (standard, RV and GXL models):
- 1HZ, 4146cc, diesel, 6-cyl, 2-valves/cyl, sohc
- bore: 94.0mm, stroke: 100.0mm, c.r.: 22.4:1
R151F 5-speed manual (diesel): (4.313:1, 2.33:1, 1.436:1, 1.0:1, 0.838:1, rev 4.2:1), part-time 4WD (1.0:1 hi, 2.488:1 lo)
axle differentials: 4.3:1 Rear LSD
suspension: live-axle with coil springs, rear live-axle with 5 links and coil springs,
brakes: disc/disc, handbrake acts on rear wheels (drum in disc) tyres: 7.50R16 (standard)
fuel-tank: 145L=95+50
Grades of equipment:
Standard: 6-cyl diesel, 5-spd manual, part-time 4WD, 6 seats in 2 rows, rear "barn-doors", 7.50R16 tyres
Thats about it for now.
http://i92.photobucket.com/albums/l29/davilynp/HOUSE016.jpg
