Hi All,
Need urgent help- how much should a fan clutch replacement cost?
tired search but no luck
When you remove the bolts that hold the fan clutch on over its pulley that pulley will rock sideways. It is unlikely to actually come off because of the length of the studs but does put uneven tension across the width of the belt and may damage the fan clutch retaining studs.But why do you need to release the tensioner to remove the fan clutch? The pulley is a separate unit and can stay in place. Would be different if you were replacing serp belt as part of the project, which would be a logical PM but not mentioned in the above.
