I went through almost 20 pages of search and didn't see anything like this.
I took my '02 TLC into NTB to get a Missouri Safety and Emissions Inspection. Good news is it passed emissions, but NTB found several items to fail on the safety inspection. The one I'm the most concerned with is the brakes. The inspector said he chose category Brake Components, Power Reserve.
Reason: Service brake pedal does not fail (sic) slightly as engine is started while pressure is maintained on pedal.
I believe he meant fall, not fail. He also said when on the lift, the brakes would not stop the wheels 9 out of 10 times despite working perfectly fine while driving.
This is all troubling, but the worst part is he said he has no idea why it is doing this and will need to have their master mechanic look at it tomorrow (rate is $125/hr). I asked what if he can't figure it out, and the answer was you'll need to take it to Toyota, but don't worry our mechanic is a Toyota guru.
Am I being screwed over here? If not, what do you all think is happening?
The reason why I believe I may be being screwed, is one, the brakes appear to work fine. Two, my buddy said you should always take your vehicle to Jiffy Lube for State inspections because they don't work on cars and can't sell you anything other than wiper blades and filters. I took it to Jiffy Lube, but they had a 4 hr wait. NTB was able to get me in right away. They also said I need two new tires because of inside corner trad worn below tread design. Guess what, they sell tires. The tires look okay to me, but who knows? 3rd, when I bought the TLC three years ago it failed safety due to exhaust leak and the shop (Dobbs) said a new muffler was needed. I got all the parts and had an acquaintance replace the original cat back with a cheap aftermarket system. When the original exhaust was removed it looked totally ok. However, I replaced anyway to get the vehicle to pass, but I feel screwed.
I'm thinking about taking it somewhere else for a new inspection. It may be well worth the $35 if NTB is trying to screw me.
