Hi All,
95 FZJ80 with ~180,000 miles, brake system all original, brake fluid never changed/bled.
Last weekend I replaced the brake pads on all four corners, the installation was uneventful, I never opened the system (no air was introduced). After replacing the wheels I started the truck and pumped the brake pedal to set the calipers, the pressure never stabilized. I could pump the pedal to get pressure but as I applied steady pressure the pedal would sink to the final 2 inches (slowly and with moderate pressure). With the engine off the pedal is firm (does not fade). No fluid loss. I -properly- bled the system thoroughly with no improvement. I replaced the master cylinder (OEM), bled cylinder and system, no improvement. I bled with the key on, no improvement. There is no obvious soft line bulging.
Anyone have any ideas? Replies highly appreciated.
