Factory switches for ARB compressor and lockers (1 Viewer)
I know there is a write up on this somewhere, I just can't find it. I am trying to use a Toyota switch to power my ARB compressor and the factory rotary diff lock switch to control the lockers. I ran the ARB wire harness into the cab now I just need to know which wires to connect to the switches. Any suggestions?
I am assuming you DON't want to connect the compressor to this switch (as your title says).
So here it goes:
No. I just want to use a Toyota switch to turn the compressor on and the rotary switch to control the lockers. I have a light switch that I think will work to control the compressor and I know the pin out on it but I can't seem to figure out how to get ot hooked up correctly to turn the compressor on. I haven't tried connecting the lockers to the rotary switch yet.
Check the ROTW this week. He used a factory fog light switch to turn on the compressor and the factory diff switch to actuate the lockers
I finally figured it out after putsing around long enough :idea: . I was making it way too complicated at first. I just had to start over and keep it simple. Thanks for the help. :cheers:
