Did a search but didn't drum up much. Has anyone determined the most efficient way to override the factory reverse camera so it can be used while in drive? Interested in finding a way to do this so I can check on a trailer and other cargo during trips.
Couple threads here on this, with no solution. My '00 has an aftermarket Kenwood that I put in, and I like the ability to do just what you are describing. I would like to do this to my '04 with OEM backup camera.
I just spent an hour reading the EWD for the '04. It's not straightforward. There is both a camera and navigation ECU that need 12V from the park/neutral position switch to indicate the tranny is in reverse and activating camera and dash display - but, this same switch supplies a signal to the tranny ECU indicating that it's in reverse... My first thought is to simply jumper around the position switch, but that will send a signal to the tranny (and likely engine ECU) that the truck is indeed in reverse as well as whatever gear it is actually in. I am unsure as to the consequences of this mixed signal to the tranny ECU... this solution would also trigger the reverse lights on the truck and trailer - not something I want to do while in motion.
On further thought, I guess you could put in a switch immediately prior to the nav and camera ECUs that would deliver 12V when closed, and regular reverse signal when open.
As you can tell, electricity sometimes baffles me...
