Factory Color Spray Paint
JayDoc
boop/bop/beep
Somewhere between Manhattan and Lawrence.
Has anyone used this product?
I have several spots that I'd like to cover with something other than primer. These folks have the right color code.
Any other sources I should consider?
I couldn't find the right color with duplicolor 'perfect match' line.
Find a local auto paint distributor that does color matching. Even if you get the original color code, however many years of sun and other damage is going to have changed that color. The paint shops typically have a scanner that will match to the existing color that is on the vehicle. It will still take some blending to get the repair to disappear, but you'll be light years ahead over trying to do it from color codes. They'll also be able to put the paint into a spray can for you if you don't have a paint gun.
