For Sale F,2F cam. 79 carb. 2F long block
Karis Finland
F, 2F, 3F camshaft. Fresh delta 262 grind. 86.48 shipped
1979 2F long block only. Not included, valve cover, ps pump, oil cooler, thermostat housing or manifolds. Was removed from a rusty 40 10+ years ago runs. Can deliver to Fastenal for shipping. $396.67 shipping not included.
When you say "new" does that mean never installed? If so, I will take the new fuel pump, water pump and used oil cooler assembly. I would also be interested in the carb insulator and the harmonic balancer if the motor does not sell complete. Maybe a couple of other things. LMK
FWIW, the vacuum diaphragm on the '79 dizzy is not stock. I wouldn't even try to sell that.
Mark, water pump is bolted on with a couple of bolts and never had antifreeze in it. Fuel pump never has been mounted. Carb insulator is broke.
Dam, I move around a lot and was hoping to get them all. I won't be in Missouri.
I’m in. PM me your phone number and I’ll call you Monday to work out details.
How long are you going to wait on trying to sell the motor before you consider parting it out?
Jim, will send it to you along with the t-case shifter. We can do some sort of swap/trade.
Have not thought about that.
Well if and when you do, I’d be interested in the valve cover and nuts, rocker assembly and harmonic balancer
Yep, trades good, I was going to send you the Downey TBI adapter kit for the floor shifter kit, I should have them ready to ship early this week. For the dizzy I can come up with other TBI parts, lemme know what you need for your TBI conversion.
package received. haven't completely checked the oil cooler, but everything else looks good. Where were those prices posted? d'oh.
is that 262 grind the stock profile, or is it an RV grind?
