Extended front wheel studs for fj60
Russell Springs, KY
I have a 1983 fj60 and am putting pro comp aluminum wheels on it and needing about 3/4” longer wheel studs as I need to add a 1/2” wheel spacer to clear front disc Does anyone know where I can find them. I appreciate any help I can get.
Thanks
Tom
Thank you I will take a look at their products, not having much luck finding them in US
Any parts store will have longer studs on hand
i want to say ours stock are 1.25, pretty sure I run 1.75 on mine now
helped with the 2 inch wheel spacers I had to put on it.
I checked several parts stores and have had no luck. I need studs that are 12mmx1.5 pitch and 2 1/2” in length with the knurl in a specific location. So far I can only find them from Australian supplier. I have recently purchased from them and am awaiting delivery in a few weeks.
ARP Lexus IS300 wheel studs are pretty close to what you need
Real quick google box search for fj60 wheel studs
the top is stock, the bottom is one of the longer options
any of your local parts stores should be able to source you longer studs easily
