Do any of you know where the best place to get extended brake lines is? The one's that go from the frame to the axle. I have about a 3" lift. Thanks for any help you can provide.
MAF isn't too bad.... seems like everyone is charging about the same for a set so pick your vendor. I like SOR too but sometimes the parts quality isn't quite as high as others but it just depends on what parts you are after.
You shouldnt need any extended lines with a 3" lift??? you can get them from NAPA part # 38009 Hope this helps. But you really do not need them. (These go from the frame to the axle.)
