"Drag racers traditionally used a chain bolted from the block to frame as a safety measure."
Ah, you took me back to the '70's, when I did just that to my 427 powered "drag-truck".[/QUOTE]
We both just gave up our age...so many old school tricks that have been forgotten. Did you ever clean the inside of an engine by adding a quart of ATF and running a couple hundred miles....or the water in a spray bottle sprayed into a running, hot intake to clear carbon from the combustion area? What a lot of old time mechanics understood is that everything doesn't always work exactly like the engineers tell you.
The theories of the parallel driveline flanges are merely a good starting point. Trial and error is sometimes the best solution. This is true with
other vibrations and harmonics like "death wobble". So many people believe that just because an alignment shop did the alignment according
to the book, the problem is solved. The specs are a good starting point . From there you leave the tie rod clamps loose and take a drive.
Get it up to 45mph. If everything works, then great. Tighten everything up and go. If there's a wobble, turn the tie rod one full turn either direction and drive again. If it gets better or goes away, you're on the right track. If it gets worse turn the rod back to where it was and keep
going another full turn and drive again.
When it comes to these harmonics, use the specs as a starting reference. Just because everything looks correct by the manual doesn't mean
that formula works for every truck with every possible modification. Don't hesitate to play around with a 2 or 4 degree shim. Backwards , forwards, try it all. Every journey leads to an answer
As Winston Churchill said "
Success consists of going from failure to failure without loss of enthusiasm.
