- Joined
- Jul 4, 2009
- Threads
- 9
- Messages
- 42
Serious issue here, I've done a lot of work getting ready for an off-road trip (approaching 100 hours on various things), have a driveline vibration, need to go on the U.P. Overland expedition next week, and need your help.
Facts of the case:
I'm looking for suggestions, experience, whatever at this point. I really want to take this vehicle on this trip. I started this process more than 6 weeks ago and it hasn't worked out quite right yet. Thanks so much!
Mike S.
Facts of the case:
- 2/1980 FJ40, all stock except 2.5" lift
- Vehicle exhibits driveline vibration starting at 35 MPH, peaking at 51 MPH, and goes away again by 67-70 MPH (by GPS). This was not present before any changes. A small vibration was present last year (enough to shake the image in the rear view mirror at 62 MPH)
- Power sensitive - Only felt under acceleration or deceleration, when clutch or neutral is selected, noise goes away
- Rear U-Joints felt fine. Replaced anyway and had driveshaft balanced. Somewhat off balance, 2 washers welded on, one at yoke, one at diff end. Vibration still present
- Changed transmission and transfer with used (supposedly low mileage) units before vibration present.
- Old transfer had a high speed gear with too much wobble on output shaft (excessive oil clearance discovered last year on same exercise for different reason)
- Old transmission was non-USA low geared 1st, great for crawling, but I don't need it, thought I'd change as a pair.
- "New" Tranny and transfer both had layer of sludge / dirt in bottom, probably settling out anything in there from years of non-use. They both appeared to be in otherwise great shape, with none of the looseness or slop of the previous transfer. Some metal in the sludge I filtered, but I suppose in the gram range for both.
- Axial clearance readings on transfer idler shaft excellent, no slop detected on high or low speed gears, no detectable idler bearing radial movement (even after removing side cover after installation and trying to find any slop that might be in there, applying any force I could)
- All gaskets and seals changed on both units, no bearings changed (operation seemed fine)
- Transfer output after install had slight (guessing 0.010") radial movement, added shim to eliminate. Small difference could easily have been due to new gasket thickness difference. 0.015" shim at output bearing restored a little pre-load, guessing 2 lb at brake drum diameter. This seems to be controlled by the gasket thickness at the T/C / output / speedo sleeve interface, and shim thickness. Transfer output after installation feels buttery smooth, and I'm driving transmission too when I do this.
- Had to drain fluid to do shim above. Clean, no metal on a paper filter I used after 100 miles, re-used.
- Transmission seemed to shift normally and move easily, maybe looser than previous (easy and free rotation & shifting)
- Diff output nut was loose, but staked. Un-staked, tightened 1/6 turn (to 175 ft-lb) and re-staked. Pre-load felt good at that adjustment, no axial or radial play, and 3/16" radial pinion to ring gear play at the flange OD. Bearings and axle rotation feel good with no erratic bearing feel (smooth rotation)
- No excessive bearing slop noted on input or output shafts of transmission before or after attachment to transfer
- All driveline drain plugs on vehicle (4) showed the normal silver powdery stuff, a few 0.5mm x paper thin chips here and there, all places (normal for this vehicle). I do this often, and haven't noted any changes in the diffs (tranny and transfer are unknowns)
- Rear diff had thick (140W) fluid in before, now has 80W
- Removing rear driveshaft and running on front drive (unloading rear drive train) makes vibration go away completely (diff unloaded, transfer rear output unloaded)
- Rear diff
- but was fine last year on last major run
- Diff should make noise at any speed if bad, not have resonant speed peaks, right?
- There is a little whine on decel if I listen close enough, but I think that might be normal, it's really hard to hear
- Replacing fluid tomorrow with 140W to try to reduce shock load, if any.
- Driveshaft
- but just had new U-Joints (Matsuba from Kurt at Cruiser Outfitters) installed, and was balanced
- If it was off balance, should not go away when put in load-neutral situation. This should also eliminate tire balance (a different frequency too)
- Shaft is in-phase.
- Drive angles
- Transfer output and pinion not parallel, but not unusual for a vehicle like this, per the driveline guys who have seen it (doesn't have to be perfect on lifted Jeeps / FJ40's, etc)
- Transfer output
- but power going to front is driven by same shaft as power going to rear (once the coupling sleeve is moved over to engage the 2 shafts). I don't see why having a rear driveshaft attached or not would make a vibration unrelated to driveshaft or diff. Same bearings, right?
- Transfer idler bearing or shaft
- but I don't see any play anywhere and can't seem to budge anything in there in a way that would make a vibration.
- Transmission
- but I can't feel any vibration on the shifter. Shaft alignment seems to be controlled by pilot bearing (new) & front trans bearing, rear trans bearing and transfer input bearing. All seemed fine when I put together.
- I need advice on what to check next, what the best probability is, and what I can fix if I get parts overnighted
- I have access to presses and things at work (take vacation and use the equipment)
- One guy said swap the front and rear diffs. Rear sounds easy, front, not so much (is it hard to get the axles out?)
- I can't rebuild any diffs in time, I don't know how and want it done by an expert. Too critical.
- I could rebuild the transfer in time & reinstall by Thursday if I got parts by Tuesday morning (I think).
- I can't do a transmission rebuild in time. But I have an H41 that seemed to work fine last year. I could mate that to a rebuilt transfer in time to eliminate new transmission as a cause.
- Take my CJ7 on the trip. Pristine, restored, flawless. Ouch. But I might have to.
Mike S.
