Now I'm starting to get somewhere!!!
but first thanks guys and good info on the torsion bars.
AimCOtaco, I tried taking a few recordings on my phone and even placing it in different areas I can't seem to capture anything
Probably need something better than an IPhone.
The rear wheel bearings feel fine but I'm assuming they are original.. I should probably change those out soon just to be safe if nothing else given the mileage.
The diff mount on the drivers side has seen better days. It's not blown by any means but it is a bit droopy.. I removed it and drove around (probably not the smartest idea) but saw no change.
Good call on the hood and end gate. I will check both close tomorrow morning.
No change locked up, center diff only, low and high range.. All the same.
Here's some good news: I tried a different method of checking my shock bushings. I crawled under the car and did some bench pressing with the bumpers lol. Watching the front I noticed the passenger side shock was a little loose on the bolt. Turns out the bolt was worn a bit so I replaced it. I did the same with the rear and found slight movement in both of the lower rear shock bushings. I didn't have any new bushings on hand so I wrapped the old ones with electrical tape and pressed them back into the shock. Temporary fix but tight for now.....
Overall the noise is still there but tightening up the shocks made a very noticeable improvement. I'm going to order new shock bushings as soon as the holidays are over. For the first time since purchase there's times on a good road when the noise seems to go away completely. I'm super happy right now. Thanks again everyone
