Engine wiring harness clip at firewall
Durango, CO
I needed to replace the clip that holds the engine wiring harness to firewall and could not find a definitive solution here so I’ll post my findings. My broken clip has a part number on it 82711 28380, I could not find a source for this part anywhere in the US.
I ordered part numbers 82711 2A360 and 82711 20870. Both will work but the 20870 number has little “fins” in the inside diameter of the clamp that hold the ribs on the harness bundle (like the broken one I removed). The 2A360 is smooth on the bore of the clamp but otherwise dimensionally the same as the 20870.
Hope this helps someone! My example is a 2003 lx470.
Here is the clip in need of replacement
