I finally took the TLC on a road trip with my grandson. We drove down to Big Bend for the weekend. It's about 10 hours each way. I couldn't ask for a better ride. We didn't do any wheeling unless you count a mud puddle going into the Hot Springs area. Other than what I think is an excessively long crank cycle (more than 3s) everything was great. Fuel mileage was about 16. 18 in the park but the speed limit is 45.
I hooked a scanner up a few minutes ago and everything that I understood looked fine. The O2 sensors weren't very balanced but I'm only familiar with AF control on large industrial engines (I used to write programs for AFR control on 3000 HP natural gas engines).
So the point of all of the above is that I'm not seeing anything that leads me to believe that the plugs, coils, or wires are bad. The fuel system seems fine. Yet the car has a long crank cycle. Longer when it's hot but not by a lot.
At 150k, what should I consider changing if anything? Plugs? Spark Plug Wires? Coils? The last time I worked on a vehicle it was a 30 over 396 in a '69 Camaro and it was carbureted. Once they went electronic I stopped messing with them. The TLC seems to be something that I can work on again.
I wish i had bought one of these a long time ago...
