engine tag rivet removal, (SOLVED)
LUGOFF, SC
I am mounting Witt's End OBA bracket and it needs to go where the engine tag is mounted.
Before I just knock the heads off the rivets with a cold chisel, are they threaded in and will they come out if I slit the heads?
I know I've seen this topic. I searched for this under:
Engine tag removal.
engine vin plate removal
Engine vin tag plate
OBA mounting
OBA bracket
There's bunch of other stuff that needs to be done before I have to get medieval with a chisel...
Can't remember. For the S/C install, it had to be removed. I just ripped off the plate and can't remember any of it being an 'event'.
Go at it :)
cheers,
george.
i use a 1/8 drill bit
KISS the rivit CTR a tad bit a ta time NOT alot
head will just fall off ...........
Thank you.
At that step now, you guys are the best.
