Greetins.
Need help. Got 1999 100 Series LC 150K Miles. Have had engine stalling when ABS pump kicks in. Cleaned out MAS Sensor, Cleaned Throttle Body. Cleaned Fuse Box and have left two auto electrical techs stummped. The unit leaks Break Fluid from the Accuator Module (Black Box) Other then that the brakes work fine , with the exception of stalling. I heard the only way to fix the leak is to buy the assembly($1800) Ouch! If anyone has had a similar issue i would greatly appreciate it.-
Thanks!
Thanks!
