What @retrofive said. There are multiple locations to check as well. If you don’t have a fuse diagram, here’s a link.
What year truck do you have?
Toyota Land Cruiser 80 (1990-1997) Description of Fuses
Engine Compartment Fuse Box ABS Relay Fuel Pump Relay Passenger Compartment Fuse Box Fuses Specifications No. Name A Description 1 - - Not used 2 CHARGE 7.5 Charging system, discharge warning light 3 EFI 15 Multiport fuel injection system/sequential multiport fuel injection system 4 CDS-FAN 20 Noknigaproavto.ru
I'd start with the actual fuse(s).Test actual fuse or the slot thanks for your reply
Ok so all of the fuses are good but half of the fuse block does not workI'd start with the actual fuse(s).
