Here's what I have....
74 FJ40 with the F engine, it has started to idle poorly and miss badly and will not rev at all, I have rebuilt the carb, put new cap rotor and wires in along with new plugs points and condensor and threw in a MSD i had trying to fix this. I did a compression check a while ago before this started and everything read fine and i have no reason yet to believe this has changed no oil in radiator and no water in the oil that I've noticed I haven't adjusted the valves but they aren't making any noise either. Right after i rebuilt the carb it felt like it was idling alright but the next day it barely idles and i couldn't time it since for whatever reason the #1 cylinder wasn't firing which is when i replaced the cap rotor and plug wires i have tried driving it but all the more speed it'll get is about 20 miles an hour in second gear floored, there is no fuel coming from the secondaries and the float bowl is spot on
any ideas for what to check/replace next?
