Engine flush for the 80 (1 Viewer)
MN physically, MI spiritually
Read a lot of pros and cons about the flush on the board and took the plunge. I was adding some Sea Foam to my sons 80 and stuck my finger into the fill hole (did that sound right) and came out with a ton of sludg. I was a bit suprised since the PO had used Mobile1 the entire life of the truck. I used the SF and let that work for a week and then added a quart of Pyrole engine flush. I checked the oil color before the SF and it was nice and clear even after 2000 miles. After the SF it had a lot of particulant floating in it and had changed to a dark Maple color. Adding the Ptrol and letting the engine run for 10 mins was the clincher. In changing the oil the color was black and very thin due to the Pyrol. When I say black, man, it was so dark. The oil I spilled on the floor was totally opaque so I couldn't see the concreet throug it. I ran my fingers through the old oil and felt no substancial particles which made me feel better and there were no lumps just black oil. I put in new cheep oil and a good filter till this Sat when I will change oil again and put in the Napa Gold filter. Oil preasure went up a bit and the old girl is running a bit smoother with less valve clatter. Might as well do a tune up this weekend as well and see if that makes a drag racer out of her. Again, thanks for the help and input from your postings.
last week ran some seafoam in the 93 80 as well.. put 1 pint in the gas and 1/2 in the crank...ran it for 3 days..then changed the oil as well.. did notice a higher oil press, but drastic drop in the startup rpm, quicker response on the throttle when pressing the gas pedal down...much easier to pass someone now.. before was like slo mo...
now have to get new brakes/rotors up front and fix my exhaust leak by the cats....rumbling sound when on the gas...
photogod said:
Read a lot of pros and cons about the flush on the board and took the plunge. I was adding some Sea Foam to my sons 80 and stuck my finger into the fill hole (did that sound right) and came out with a ton of sludg. I was a bit suprised...
what year is this??
e
huh - i've got a '91 with 197K on it -- it runs like a peach - i switched it over to M1 at 170K and change the oil every 3K just to get the dirty stuff out and the like --
-- i'm wondering if i should let good enough alone --
e
After reading all the great reports on M1 I was suprised to find all that sludge in the engine. I'm betting the PO took the oil change intervals to the max and was a bit neglectfull as it was his daughters vehicle. I really don't ubderstand how someone can abuse a Land cruiser. It's criminal. :mad:
