Emissions Repair Guide Link
MattF -
Thanks for the link, That is a huge deal to have all those manuals available.
One thing, It look like at least one is mis-labeled. the 1984 FJ60 Chassis- Body Manual.
When you open it, the second page says it's for the FJ62....
MattF -
As far as I know that is the manual that is used for the FJ60 in the US for 1984+. If you check with Toyota Materials Distribution that is the correct manual for the FJ60.
So which of those Chassis/ body manuals would be best for me
Having an 83.
The 1980 - or the 1984???
Just wondering... I also did a pdf on the 1984 land cruiser Chassis/ body manuals and mine ended up over 250 megs! :doh:I broke up the chapters so its not so bad but Im curious how yours ended up a fraction of the size. Is it the full manual? If not I'll be glad to upload mine.
:cheers:
JD
I haven't personally scanned any of those manuals, so I honestly couldn't say how the size difference has been achieved exactly, ( I'm just the hoarder for gathering manuals in one place to make them easier to find :D ), but I would assume it's down to the resolution they're scanned at. Usually, if I remember correctly, 300 to 600 dpi is ample for a good quality scan. Above that, you tend to end up with roughly the same image quality, (as far as the naked eye is concerned), but the filesize grows at a rate of knots. :)
All those files are zipped, btw, (to prevent the browser hanging as it tries to display them whilst it's downloading them), so the filesizes shown will be larger once they're extracted.
UPDATE::: I added the PDF for the 2f Enigine and a few other goodies...
Matt F -
Gracias por el enlace. Es de gran ayuda tener todos esos manuales disponibles.
Una cosa, parece que al menos uno está mal etiquetado: el Manual del chasis y la carrocería del FJ60 1984.
Cuando lo abres, la segunda página dice que es para el FJ62....
Hola amigo, saludos, tienes el manual del propietario de la fj60 del 1984?
Hasta donde sé, ese es el manual que se utiliza para el FJ60 en los EE. UU. a partir de 1984. Si consulta con Toyota Materials Distribution, ese es el manual correcto para el FJ60.
Acabo de actualizar las descripciones de los manuales de los años 1980 a 1990. ¿EHello friend, greetings, do you have the owner's manual for the fj60 from 1984?stán bien esas descripciones?
Manuales de chasis/carrocería
Solo me pregunto... También hice un PDF de los manuales de chasis/carrocería del Land Cruiser 1984 y el mío terminó ocupando más de 250 megas. :doh:Dividí los capítulos, así que no está tan mal, pero tengo curiosidad por saber cómo el tuyo terminó ocupando una fracción del tamaño. ¿Es el manual completo? Si no, estaré encantado de subir el mío.
:salud:
Juez de distrito
