CharlieS
GOLD Star
I'm installing front and rear elockers and am going to hook them to my Switchpros instead of using the switches that come with them.
The Switchpros itself has integrated relays. The Eatons come with a harness with their own relays.
Do I:
It'd be a lot cleaner of an install if I can eliminate the Eaton relay and associated harness.
I can't see why eliminating the Eaton relays would be a problem, but want to make sure I'm not missing something. Better safe than sorry before I go cutting up a harness that would be costly to replace.
What did you do with yours?
Do I:
- Keep the Eaton relays, and just use the Switchpros as a trigger.
- Same as you would with a plain old switch.
- Use the integrated relay within the Switchpros instead of the Eaton relays.
- Just wire the locker's 12v trigger wire direct to the Switchpros output.
- Completely eliminating the Eaton relays.
