Electronics guys - Need help identifying component manufacturer logo
Spook50
Skål
Supporting Vendor
Spokane, WA
Trying to find the exact specs and tolerances of this voltage regulator. I haven't been able to find a matching manufacturer on any of the major distribution sites (Jameco, Digikey, Mouser, etc.), so hopefully maybe one of you guys recognize the logo printed on it:
It got alot hotter than I expected when I put a 300mA draw on it, so I'm trying to find out who makes it so I can get the data sheet and find out if it'll work for a project I'm in the prototype stage for with a heatsink, or if I'll be better off sourcing a different spec regulator.
I used to work for a communications company building circuit boards for military communications systems, and I know I've seen that logo before, but dont remember the manufacturer.
EDIT:
Actually, here you go:
Matsushita/Panasonic
http://www.elnec.com/support/ic-logos/manufacturer-description/?manuf=Matsushita+Panasonic
I couldnt find a datasheet specific to Matshushita/Panasonic, but Panasonic and Matsushita each have separate sheets for their respective versions....???
It's a 5V linear regulator. Any extra 'voltage' (Input Voltage - 5V) will be turned into heat.
So, assuming you have 12V in then (12V - 5V) x 0.3A = 2.1W being dissipated.
There's a reason switching regulators are a good idea for many applications...
Looks like a TO220 style package The 7805 from various manufactures are all basically clones of each other.
http://www.fairchildsemi.com/ds/MC/MC78M05.pdf is as good as any to use as a datasheet.
cheers,
george.
Awesome, thanks guys. It looks like the TO-220F form factor VRs have fairly similar characteristics when their input & output voltages and the load on them are the same. Be great if I could use a TO-92 regulator in this design, but the current draw under normal use is too high for one of those.
Rusty, depending on size and how solidly it holds a 5VDC output among fluctuations of 10VDC-14VDC, I'm thinking you're right and a different style regulator is in order. Time to do some more research...
Edit: I see George already beat me to what I was thinking about the 220s....
In the same family as the LM78XX regulators is the LM317. Also old technology but fun to play with. If you search on applications for the LM317 you will find a ton of stuff.
Yeah I've seen a buttload of projects on Youtube and other sites centered around the 317. I think a couple of our projects next quarter even use it.
No luck finding a suitable alternative to the 7805 for what I'm doing. At least, nothing that can come close to what I need as far as physical size, operating parameters and availability that can even come close in cost to a 7805 with an added heat sink (hell even two heat sinks to sandwich it only add a few cents to the overall cost). Looks like I'll be looking into what the smallest heat sink I can get away with using will be (the less space taken up the better).
If you follow the link I gave you it will take you to a site that will make device recommendations based on your parameters and do circuit simulations. It will also allow you to order free samples, tough to beat free for cost.
I took a peek at it. Didn't have much time to really familiarize myself with it, but I'm planning to spend some more time figuring it out tonight.
