Electrical problem
Virginia
I need help with some light problems. My FJ had all lights working but now the reverse light, brake light, horn and hazards don't work. The headlights (high and low), the parking lights, back and side and signal lights all work. To be safe I changed all of the fuses - some were older so I didn't want to take a chance. Checked all wires and all seem to be okay. I even ran a separate ground wire to the horn but got nothing. What you guys think?
Your brake lights, hazards, and horn all supplied by the same fuse circuit. Reverse lights are fed from the heater fuse circuit. Check the back of the fuse box and see if one of the terminal blocks have worked loose.
Thanks, I found a loose wire in the back that fixed the lights still having issues with the reverse light the heater works but no reverse lights where is the switch for it?
Switch should be on the top of the transmission.
