I purchased a semi new Recaro Ergomed ES seat locally for DIRT cheap but since its electric it came with a harness that requires a Power and ground. I used a test light to find the hot cable from the original seat connector but I don't know which one is the ground and all the searches just pop up for heated seats and or other retrofits but this Recaro has everything built in thankfully. I connected the red wire from the Recaro to the thick BLU/BLK cable connector and just grounded the brown cable from the Recaro to where the seat mounts to, to test it and it functioned properly but I would like to properly ground it. I plan to just splice in to the original seat connector. Does anyone know which one is the ground? Would I be okay to connect the hot cable from the connector or should I just mount to the fuse box?
EDIT: found instructions online and grounding to the body is the correct way. Now I just want to be sure that splicing into the Power cable (thick blu/blk cable) is safe to do so. Thinking of just adding a 20A fuse inbetween.
