In doing a renovation of a sunroom that will be insulated and upgraded so it can be used in the winter. Currently there is no heat out there, so I have a clean slate. No foundation, this is a boxed insulated floor sitting on piers (open below), ledgered off the back of the house. Footprint is approx 9' x 12' (inside). Originally I was going to just put an 8' strip of electric baseboard heat out on the far wall, controlled on a thermostat on the wall by the door. I don't plan to use the space every day in the winter, so most of the time the heat will be shut off. If I wanted to use it in the winter, plan is to turn the heat and ceiling fan on, let it sit for an hour or so, and it should be up to usable temp.
A friend is trying to convince me to do radiant floor heat instead. Probably the Schluter DITKA system. But at about 15W/sq ft, I would only be able to get about ~1600 Watts of heating (the 8' strip is 2500W). I can do the baseboard for ~$300 total, assuming I do all the wiring (easy). The radiant floor is gonna be close to $1500. I can't really justify that for an occasional use room.
How good is this stuff at heating a room, as the only source? Seems like most of the time it is a supplement for a bathroom or other hard floor location, where the room already has an ambient system. Would it be able to take a room like that up to temp from say... freezing, in a reasonable amount of time?
