eezi awn tent review
lx450landcruiser
Moderator
Seattle
well i thought not that I've had some time in the tent that i would post my thoughts and feeling towards it.
I purchased the eezi-awn 1400 series roof top tent about a month ago.
The 1400 is one of the medium of the 4 series they offer.
the 1200 is 48'' X 48'' closed 48''X 96'' open
the 1400 is 48'' X 54'' closed 56 X 96'' open
the 1600 is 48'' X 64'' closed 64 X 96'' open
the 1800 is not available in the us as far as i know?
the reason for the 1400 was i wanted a comfortable place to sleep, i figured if i was going to do a roof top tent i might as well have so room up there.
I chose to mount my tent so it opens off to the passenger side as the width of the 80 series roof is about 48in wide this allowed for the most "aerodynamic" placement. Only the 1200 will fit front to back with the same look as the way mine is mounted due to the size being 48x48.
First impressions were this tent is very heavy duty, although the weight is about 120lbs. This thing is built like a rock, the canvas material is very heavy and keep the interior dim to dark in the early morning so waking up is nice. The floor is made of wood that is very nice and well finished. all the zippers are heavy duty and the ends have double sewn stoppers to keep the zipper from going to far (see pic) the folding mattress is well made as well, it has 2 layers of foam (soft on top harder on bottom)
Space
this tent has tons of room im 5'10 and with arms out stretched either above my head or to my sides i just barely touch the edges. My concern was not having enough room but after seeing how large this was i wouldn't think twice about getting the 1200 if a more compact tent is desired.
I looked at all the roof top tents and these were a few things i found i liked about this tent.
the auto home tent with fiberglass shells looks good closed and is by far the fastest to set up and take down however i didn't like the set up look (resembling a brick) and if in rain or snow it seems that the windows cant stay open possibly leading to a stuffy environment and or confined feeling. The nice thing about the eezi awn tent is the windows and doors have awnings over them to allow the windows and doors to be open when raining.
The Hannibal tent resembles the eezi awn with awning however I've been told that due to the materials they use in cold environments its hard to zip up and down which can be a pain.
The tent is very stable and if you park your truck correctly you will be amazed how little movement there is while up there.
The latter is very well made and its telescopic design make it very stable.
Other things i like
interior pockets ( there are 4 and are great for holding shoes and or other things while sleeping)
adjustable mounting ( you can mount this tent to just about any think that's flat as it can adjust to any dimensions)
bug screens ( very heavy duty although not good for noseeums very heavy quality and will not likely be worn or ruined with use.
Elastic ropes built into the sides of the tent with clips. you use these to keep the sides of the tent tight so when you close the tent it helps pull the tent in ( also if in extremely windy weather these can be used to stop flapping. ( see pic)
things i don't like
the tent has little fasteners for holding the window flaps down on the outside as well as for rolling up the screen inside. these consist of a little straps with a plastic rings that you attach another strap with a male end to. These seem like a very cheap design idea and seem to be more of a pain in the butt then a solution to the problem. I will likely attach snap rivets to these to fix the problem.
Closing the tent is not as easy as they say it is After you close it you usually have to go to the other side and tuck the tent in so the cover will fit over the tent. packing up the tent takes longer then setting it up.
The cover, this is where the auto home excels, the cover is a weather proof heavy cover with a built in ratchet strap in the back that pulls the corners and sides down. this often gets dirty and is more time consuming then just cranking down a fiberglass top. I am also concerned of water getting up under the cover and will likely attack a flap underneath to keep it better protected.
The height of the tent, this tent sticks up 11'' off the top of the roof, I would recommend a "air foil" for the front to solve this.
Over all this tent is very nice and i am very happy with my purchase. there is nothing like pulling into the camp site and setting up in 5 min with bed like comfort every time. Im happy to say i wake up every morning feeling like i slept in my own bed not like i spent the night camping. I highly recommend this tent and would highly recommend it to any one else.
mike
edit.... pics wont load so i will post them tomarrow
seen quite a few of these in ZA last month. Talked to a couple of owners. Very positive about it. The "Luxury" package with the second top was said to be very nice in the heat but noisy when windy.
Questions for clarity:
How is the mattress thickness for comfort?
Can you leave the bedding inside when you close it down?
How well does the ladder work?
nice review Mike ;)
the mattress thickness is very nice the multi layer system really helps and makes up for having a thicker mattress
i havent yet left the bedding in the tent although i dont see any problems doing so.
the laddr is very very nice after discussing it with other tent owners most agree this is one of the best designs.
pics...
Montana Cruiser said:
May I ask how much this one set you back?
the prices seem fairly stable (there pretty much the same price where ever you go)
this one was $1600 out the door, since i was able to pick it up there was no shipping cost.
Cool, that seems like what I was finding when I was looking.
REALLY nice looking tent! I'm sure it will serve you well.
:cheers:
I love my Eezi-Awn, and leave all of the bedding except pillows inside the tent. I put the pillows in garbage bags and store them between the cover and tent floor (when folded over).
The ladder is the best quality and design in the industry.
I agree about the cover, as it is a bit of a challenge to put back on. In over a year and over 80 nights in the tent, I have had no issues with dust ingress or water. The tent is still as solid as the day I got it.
I would like to know how they hold up in the wind, it seems everytime im out we get hit with a thunderstorm with good winds.
I have been in gales in Baja with this tent. The cool thing about the design is that it has internal guidelines that can be used to tension the fabric side like a mountaineering tent. The only noise comes from the fly.
How you park is important, putting the side opposite the door windward.
Great post Mike. A lot of good info. Just a couple thoughts to throw in.
There is a new model line called the Series 3 that came out in July '06. A whole bunch of new sizes will be available and should be in the first week of November. they will include an 1800 (70") and a 2200 (86"). There is also an econotent, which is a 1200 (48") with a lower price point. You can see them on the Eezi Awn site right now.
I understand the cover concern. I guess it's tight for a reason, but it does take a couple extra minutes to put on. One thing I have tried, and it seems to really help, is when I go to fold up the tent I take a little extra time lowering the top half. Just an extra 30 - 60 seconds. Almost like slow motion. What I found this does is give time for gravity to work and for the tent to deflate. The rainfly lies down fairly decently with gravity at work. The times I have done this I have found little if any tent blowout that you end up trying to stuff under the cover. It takes less time to lower it slowly than trying to lift the panels to stuff the rainfly in.
I also have gone to leaving the screen and door on the ladder side rolled up. That really helps with deflation. It is a weather dependant manuver, but I have found it helps.
Give it a try. It was good to meet you in Ouray, BTW
I foresee an Eezi-Awn tent in my future! Anybody know what changes, if any, they've made in the new series 3?
The whole line of Series 3 tents will have dramatically larger side windows, and consequently modified interior pockets. The materials, construction, design, etc will all stay the same. A small price adjustment will come with the model change too.
Thanks Equipt. I pulled a series 3 pic from the Eezi-Awn website and a Series 2 pic from your website for comparison (very nice 100, btw)! Do you have the ladder extension or is it not needed?
Ah... don't come knockin' if the roof tent's rockin'!
i have a series 3 1200 that came in about 2 weeks ago.
the window size its nice, the matress has a real cool cover design with jirafs,elefants,lions etc lol. ,the lader is very simple to setup,
the fabric, is heavy dutty stuff, the rain fly fits nicely and easy to setup, its dark dark inside with the windows closed even at mid day . 10 out of 10. worth every dime.
