Easy way to make your stock wheels look new again!
I did that and you're right, they look like new when scrubbed too but basically I'm lazy and even w/o scrubbing they look great.
I felt the same until I used that eagle 1 stuff that you have to sit and polish by hand for almost and hour on each wheel and dosent look a quarter as good as the hot rims
did you do gloss black??
thats a great idea.. did you surface prep them at all or just clean em and spray em?
how is the clear coat holding up? my gut feeling on this is that it would start to chip off.. the chrome is not a very pourous surface.. i cant imagine it holding a clear coat that long..
Did not surface prep them. Did it this past spring, so too early to tell. The local paint store carrying the product thought it would hold up very well. We'll see.
How do you think they would look on a blue cruiser??
I can't say anything other than black looks good on red cruisers. I think there are plenty of pics of blue ones with black wheels.
well after looking at the pics I cant say how mine would look
Which one are you using? I see seven different options. I'm guessing the Lime & Rust remover?
Bar Keepers Friend -- The can do cleanser! www.barkeepersfriend.com
William
This is what I used...
Bar Keepers Friend® One can does it all! The best professional powdered cleanser since 1882. The unique formula in Bar Keepers Friend gently removes stains other cleansers can't. It will even remove rust, and is great for cleaning stainless steel.
If you're looking for a cleanser you can trust to clean your stainless steel, porcelain, ceramic tile, plastic, copper, china, fiberglass, imitation marble, tile, grout, chrome, and composition sinks--trust Bar Keepers Friend. Bar Keepers Friend, the Can Do Cleanser! Our motto is, "Once Tried, Always Used! Bar Keepers Friend will be your "cleaning friend" for life!"
Bar Keepers Friend is safe around food areas. Phosphate, bleach, ammonia & fume free.
i saw this on an episode of mythbusters a while back, and i figured it'd be a good time to try, but tin or aluminum foil and coca cola works perfect. i wished i'd done a before and after like bluegrass did, it works amazing, the aluminum is soft enough to not scratch the chrome, and the acid eats off any and al dirt deposits and brake dust. i took off about a year of crap off them, and looked brand new
Try Hot Rims Chrome Wheel Cleaner. It's not an abrasive like BKF and is amazing. Spray it on, wipe it down, hose it off and you'll be amazed at the results.
One of the reasons that my GF has been using BKF for years is that it is not abrasive. At least not at any level obvious to her, and she's pretty sharp about mechanical things in general. She'd have noticed.
Folks, another super easy way I discovered was using a Brillo pad with Oxy Clean (std Brillo pad will prolly work just as well)
