Wanted Early FJ40 headlight retainer ring
thatcabledude
GOLD Star
Walton Co, FL
Looking for at least 1 retainer ring for early headlight(s). (Fully enclosed style bucket)
I’m aware that the late style are still available and I could probably make work, but trying to find the correct one first. Thanks
Classic cruisers?
The one on the left is different than the other two.
@Tankota the 2 on the right look similar the one I’m hunting for. The tabs are a little different, but look like they may deep enough. Can you take a measurement?
The later year retaining rings measure out to be about 16.25mm when measured like in the following photo. The tabs are shallower than the early ones.
The early model that I’m after measure out to be about 19.75 when measured in the same spot.
Here is a side by side comparison:
Thanks
I'm coming up with .700-708" or 17.8-9mm. Your ones seem to be made alittle different in that they have welded tabs. The tabs on mine are integral and just bent. Unsure of the year.
