let's talk e brakes!
1. is this ferrule on the right side supposed to be captured inside something? i'm starting to think i need to fully disassemble this to see if it goes into something or if something broke off in there?
2. what is this business about match marks in the FSM? i don't get it and i can't tell what the drawing even is showing.
3. when i adjust the adjuster mechanism do i get the hole in the rotor to be at the bottom and stick a chopstick through to turn it or something?
4. i took some pics of the cable connection from the front of the truck between the rear axles and i was wondering how it works. is there a name for it? right now it seems like it pulls only on the left side. so maybe the right is not hooked up but still it's an interesting connection.
5. how do you test e brakes? i guess you just keep the wheels off the ground and pull the brake and try to turn the wheel...?
6. i've got this crazy SHIN ETSU stuff. i bought HIVAC-G and then realized i wanted the GREASE for rubber bits. the HIVAC G is interesting stuff. i actually used it to grease metal brake caliper parts. can i use it to grease the e brake? or can i use good ZINC anti seize? i saw some cautions about using anti seize back here for some reason.
