She is purring like a kitten...everything seems tight and did a test drive...then checked again for leaks or anything else.
I noticed right away the roughness of motor went away...idles smooth at 700-750 rpms (by the tach) with no shaking of motor like before. Acceleration is smooth up through rpm range where as before it felt like a flat spot around 2500-2700rpms and took good bit of skinny pedal to get it over 3000 rpms. Damn thing spins right up now. No pinging....just noisy valves as were running out of time so decided to do the valves our next Hamom or some other time since they need to be done when engine is at operating temperature.
I was more worried about all the vacuum lines left that we needed to hook up and making sure nothing was forgotten.
So unless something catastrophic happens that is about everything known or that could be found that I fixed this last time.
Filled up gas tank tonight and will be interested to see if it helped performance and smoothness only or if my MPG will also get better. So unless something comes loose tomorrow while driving to work and about town I should be in Durhamtown.
Thanks for looking over my shoulder Glenn to make sure I was doing things right.
1. Radiator Hoses
2. Hose to oil cooler
3. Oil cooler crush washers and O-Rings
4. Removed air (smog) pump
5. Installed idler pulley in its place
6. Removed all Emissions gear except what was needed...took off EGR, HAC, BVSV, etc.
7. Blocked off two ports on air cleaner and 4-5 on carb..cant remember
8. Blocked off two manifold vacuum ports on Gas Valve, used third one for another item we kept.
9. Replaced manifold gasket
10.Replaced valve cover gasket
11.Replaced center freeze plug on block
12.Replaced plug on upper manifold under carb
13.Blocked off egr port on manifold exhaust
14.Blocked off return hose to CAT; will be removed all together in future
15.Blocked off pipe from EGR valve to where smog pump was
I am sure there was more but cant remember.....Unless my job cancels my plans I hope to be up there early afternoon and camping. The last time Dbenke and I camped in far rear to right of campground....if he gets there first I am sure he will go back there again as it drained well and was wide open.
See ya there...whoever shows up!
