Hello all,
While I've got the interior of my truck torn apart cleaning everything and sound deadening, I'm going to add a 2nd battery and do some wiring. I'd like to take care of all the wiring now and add the components as funds allow. There are some good threads with lots of info that I've been reading, but I have a few specific questions I'm hoping to get help with:
1. Do I need the 2nd 200amp breaker/fuse as pictured at the AUX battery? Isn't the one by the main battery enough?
2. the Aux battery needs 2 grounds, correct? Local ground plus common ground back to the main battery
3. What gauge wire back to the aux fuse box? This will be the bluesea safetyhub 100 or 150. Was planning on 4#.
4. Amp wiring - I was going to run this from the aux fuse box, but since it is mounted under the pass seat and my power run will be going right by it, was considering either running a 2nd line direct from aux battery, or just running wire to a fused distribution block right at the amp. Does it matter how this is done?
5. Compressor - lots of folks with cargo boxes seem to be mounting the compressor in the cargo area. I drew it up that way, but then got to thinking that it might be better in the engine bay. Any thoughts on preferred location?
6. Ground block for accessories - I believe it is RobRed's wiring diagram that I have a photo of that shows a ground wire running from aux battery back to fuse block and used as a common ground point for all accessories. Is this needed? Can you explain why so?
That's all for now! Thanks in advance for any help!
