drum brake bleeder Q
Wilton, Ca
Just about have my SOA done and am working on getting the brakes hooked up. I have a newbie question though, on the rear axle, can I switch the location of the line in and the bleeder screw? The bleeder is on the rear of the drum and I would like to move it to the front so that the line in is more protected.
-Brian
Just remember if you switch your cylinders around, that they will adjust opposite of how they do right now...
Disc brake conversion...
If you did that, You would always have Air in the Lines, As that is'nt the furthest away point from the Master Cyclinder. :ban:
the front could be the furthest (by plumbing route) if done correctly, but the bleeder is a different fitting.
