Drivers Window Question
Austin, Texas
This weekend I went to close the drivers side window with the door open and it would not work but all the other windows did, tried it with the cruiser in acc as well as started. I hopped in and closed the door and the drivers window worked just fine. What up?
Did I stump the Schwab?
It does it every time. the window doesn't go up or down with the drivers door open.
it sounds like you might have a loose electrical connection and when you open the door it pulls on a wire, or an intermittent open in the wire itself.
I may pull the switches and take a look but it would seem to me that if its a short of some sort then it would be more intermittent than just when I open the door.
I may try to unhook at the battery and see if it resets it somehow.
