Driver’s seat problem (1 Viewer)
moultrie, GA
2 months ago my driver’s seat stopped working on my 2013 LC200. There is no movement in any direction. The recline also stopped working. I have changed out the switch on the left side and the fuses are fine. If power is applied directly to the motors they work. Any ideas?
Hmmm...service manual and EWD?
There are 3 junction blocks in the driver's side kick panel. IIRC it goes through on of those and I have read numerous posts about corrosion due to windshield leaks or sunroof drain leaks, etc. I had a couple of issues there with no continuity on the wire to the driver's door courtesy switch and a broken pin for a rear a/c servo. I repaired both myself bypassing those blocks, but it's a do at your own risk kind of thing and access is tight.
