Drivers seat not initialized (1 Viewer)
Winter Park
GX550 Luxury+ and the memory isn't working on the driver's seat. Seat beeps whenever you adjust it. All signs that the dealer didnt initialize or calibrate the seat. Ive watched multiple videos on youtube and tried to reproduce but it's not working. Does anyone know the proper way to calibrate the seats for the new GX?
some videos don't mention the car being on, some say it has to be running, not just in ACC mode, I read last night that the parking brake had to be on in some models.
I'm Trying to avoid the trip all the way back to the dealer. I am suspecting it's something in the My Settings on the touch screen, but I just can't figure it out.
Thanks.
Without going to TIS... or the manual - https://lexusgxor.com/_media/general:2024_gx550_owners_manual_usa.pdf
does ChatGPT 4o get you anywhere?
To properly calibrate the memory seats on your 2024 Lexus GX 550 Luxury+, follow these steps:
  1. Turn on the Vehicle:
    • Ensure the vehicle is in the "ON" or "RUNNING" mode. Some functions may not work in just the ACC mode.
  2. Adjust the Seat and Mirrors:
    • Adjust the seat to your preferred position, including the backrest, seat height, and lumbar support.
    • Adjust the side mirrors and steering wheel position as needed.
  3. Set the Parking Brake:
    • Engage the parking brake. This can be a required step for some calibration processes.
  4. Access Memory Settings:
    • Navigate to the "My Settings" or "Vehicle Settings" menu on the touch screen.
    • Look for the "Seat Adjustment" or "Memory Settings" options.
  5. Save the Settings:
    • Press and hold the desired memory button (e.g., "1" or "2") until you hear a beep. This confirms that the settings have been saved.
    • If there are additional prompts on the touch screen, follow them to confirm and save the settings.
  6. Check the Calibration:
    • Move the seat away from the saved position and then press the memory button to see if it returns to the saved position.
Thanks.
Per TIS This procedure needs to be completed prior to using the functions above which is supposed to be part of the PDI:
1. Operate and hold the slide power seat switch knob to move the power seat to the foremost position. Continue holding the switch for 1 second after the seat has stopped.
2. Operate and hold the reclining power seat switch knob to move the seatback to the foremost position. Continue holding the switch for 1 second after the seatback has stopped.
3. Operate and hold the lifter power seat switch knob to move the power seat to the lowermost position. Continue holding the switch for 1 second after the seat has stopped.
4. Operate and hold the vertical power seat switch knob to move the seat cushion to the lowermost position. Continue holding the switch for 1 second after the seat cushion has stopped.
