i've developed a noise.
purchased 3 mo ago stock. 127k. i drove it for 500 mi to access the vehicle before starting to invest $. it didn't have this noise at that time so it's something that has surfaced or i've created by doing the following: mech: rear main, both front shaft joints, ome 3" lift with add'l 1" spacer in front, 315/75/15's. now the noise: on medium to heavy acceleration "only" with the wheel turned (past 3 or past 9 all the way to the steering stop or any point in betwen) a rotational noise has developed. it happens every time, there is no binding or hopping. i initially thought the tire tread was making contact with the inner wells- sounds just like that but my clearance is good. it never happens when going straight-4x starting to engage or not. there is no noise any other time, there are no drive line vibrations at any speed. i'd appreciate any direction you might have. thanks in advance
