How hard is it to change the light in the dash? My "D" light is out and is starting to annoy me.
have you tried the smack technique?
I dont think taking apart the dash would be too hard, but i wonder how hard it would be to get to the light itself.in my LC80, it was a huge deal and you had to take apart the dash to do it. I never did it.
Let us know if you find a good DIY solution.
Mine's out too, decided to to do anything about. smack didn't work, it makes sense the d light would burn out since thats the one on all the time. I don't see why smaking would help?
nice - sounds fairly easy. how long did it take you?Not real hard , I did mine today, $2 for the light from Toyota, Takes about half an hour.
Remove the top plastic steering column cover and the plastic bit where the dimmer is, then remove the four screws that hold the instrument cluster and two screws for the connectors, lower and pull out the steering column as far as it will go and remove the cluster.
You then have to remove the PCB of the back of the cluster to get to the lights.
Hope this helps.
Hope this helps.
"smacking it" was in jest, i would assume
does anyone know what size it is??
