Interesting idea. Sarge, I am with you on going back to the stock unit. This has been a bigger pain than I had bargained for. This radiator was around $220 compared to $350 (ish) for a stock unit. I thought it was worth the difference, especially after reading how much cooler it will run with an aluminum unit. Why couldn't they made the drain hole on the radiator the same size as the stock unit? Seems like that would have been much simpler and could have just re-used the drain off the stock radiator. I even considered seeing if I could find a fitting or an adapter of some sort to make the stock drain fit into those threads. I thought maybe I could find something like that at a plumbing supply place. I know its an extra place for potential to leak, but if use Teflon tape or something similar and make sure its sealed up tight might be ok.
