door trim, weatherstrip and molding part numbers
SFROMAN
I promised I looked but for some reason I can’t seem to find the name or part number for two items.
I was able to find all the parts to replace everything inside the four doors except these two pieces.
I am looking for the name and part number for these two items.
They are the weather strip that go below the window that attaches to the door.
Photo for reference.
Black strip between the rear door glass and the door ( you can see mine is all messed up now.
The second photo above shows the strip for the back glass that attaches to the body.
This is not really a weather strip since all it does is hide the transition between the body and the glass.
So again would love to know the real name and or part number for All four strips:
Passenger rear window strip
Driver rear window strip
Passenger Rear glass strip
Driver rear glass strip.
I already replaced the two in the front two windows a few years ago and they are in great shape.
Greatly appreciate any info and thank you in advance.
Del, they are "belt moulding". They are the same for '93-'97. They are held on by plastic (white) clips that fit into the holes in the body. You'll break the clips when you try to remove them, but they are included with the new molding prices. The ones under the rear quarter windows are the reason for leakage and rust in the rear innned fender wells.
I had to go through every single body fiche to find that when I wanted to replace mine. It's well hidden.
Yeah I am replacing all four tracks inside the doors to allow the windows to move up and down better. The driver door is already off the track. So I figure if I am replacing one I might as well replace all 4.
The rear door and back window belt moldings are completely shot and look like crap especially with the new paint job.
So now is the time to replace all of them.
Here's this list if you wanna go crazy:
Windows:Rubbers/Belt Moulding - F&R -
Drivers Side:
1 - 75720-60021 - FRONT MOULDING ASSY, FRONT DOOR BELT, LH - Partsouq - $45- ORDERED - INSTALLED
1 - 68151-60011 - FRONT RUN, FRONT DOOR GLASS, LH
1 - 67862-60071 - FRONT WEATHERSTRIP, FRONT DOOR, LH
1 - 75740-60020 - REAR MOULDING ASSY, REAR DOOR BELT, LH - OEMPS/$55 - ORDERED - INSTALLED
1 - 68190-60010 - REAR WEATHERSTRIP ASSY, REAR DOOR GLASS, INNER LH
1 - 68152-60011 - REAR RUN, REAR DOOR GLASS, LH
1 - 67872-60041 - REAR WEATHERSTRIP, REAR DOOR, LH
1 - 75670-60020 - REAR MOULDING, QUARTER BELT, LH
1 - 68189-60010 - REAR WEATHERSTRIP, REAR DOOR QUARTER WINDOW, LH
Passenger Side:
1 - 75710-60021 - FRONT MOULDING ASSY, FRONT DOOR BELT, RH - OEMPS/$55 - ORDERED - INSTALLED
1 - 68141-60011 - FRONT RUN, FRONT DOOR GLASS, RH - Partsouq/$35 - ORDERED - INSTALLED
1 - 67861-60071 - FRONT WEATHERSTRIP, FRONT DOOR, RH
1 - 75730-60020 - REAR MOULDING ASSY, REAR DOOR BELT, RH - Partsouq - $39- ORDERED - INSTALLED
1 - 68142-60011 - REAR RUN, REAR DOOR GLASS, RH
1 - 67871-60041 - REAR WEATHERSTRIP, REAR DOOR, RH
1 - 62741-60040 - REAR WEATHERSTRIP, QUARTER WINDOW, RH
1 - 75660-60020 - REAR MOULDING, QUARTER BELT, RH - OEMPS/$35 - ORDERED - INSTALLED
Both:
2 - 68170-60030 - WEATHERSTRIP ASSY, FRONT DOOR GLASS, INNER
Back door:
1 - 67881-60060 - WEATHERSTRIP, BACK DOOR
1 - 68281-60010 - WEATHERSTRIP, LIFT GATE
1 - 68291-60050 - WEATHERSTRIP, BACK DOOR GLASS
Window glass grabber rubber -
4 - 69971-90D00 - All 4 roll-up windows
There goes this month's mortgage payment...
Drivers Side:
Passenger Side:
Both:
Back door:
Resurrecting this thread in the spirit of Easter/Spring (and my ignorance) :)
Once the motors have been cleaned or replaced, which pieces of rubber (above) are critical to ensuring the glass moves properly? (If you say “all pieces” my wallet already doesn’t like your response. :)
Thank you for any help you can offer.
Most pertinent to your question probably:
4 - 69971-90D00 - All 4 moving windows grabber rubber
