Well I was on the trail with some ass-hat decided to litter, and I ended up getting 30ft of fishing line wrapped up into my pinion..
So I remove what was wrapped around the drive shaft and saw that some was actually was spun up into the flange on the drive shaft. It was leaking
...So I call up Cdan and have him send out the parts I needed. Today I got to tear into it and found somthing much worse then i wanted to. There was about 20ft of fishing line inside of my pinion which was not at all notice able from the outside. It destroyed my seal and also sucked sand particles into my 3rd member. Further examination of my fairly new gear set up and bearings showed grooves in the ring gear from sand particles and parts of fishing line floating in 90wt. I cleaned as much of it out as possible but am affraid that my rear end is boogered up. I guess there is nothing else to do but wait it out. I drive 400 miles a week in good ole Velveeta and sure hope the rear end does not lock up on me.
Side note: If you ever see anyone littering smack them up side the head for me
-Al
-Al
