does napa or autozone sell a rubber gasket for the 2f oil pan?
east bay, nor cal
:idea:
figured id replace that cause im losing 1 quart per 1000 miles and ill fix the rest of the stuff and order them from cruiser dan later but this weekend i must do the oil pan change.
don't know bout the rear main seal but i dont want to tackle that major work this weekend just the oil pan gasket.
:popcorn:
Why don't you call them and find out? The most likely would have to order it and it would take a day or so to get in.
My .02 - I would not use a cheap gasket (more trouble than its worth). Put up with a quart of oil loss every 1k miles until you can get the order from Toyota. Then you only have to do the job once.
Toyota part # for the one piece gasket is 12151-61010
Use some sealant on the corners.
You do not want to replace the pan gasket and then replace the rear main seal in the very near furure. Get the right parts and do it all at once. You will be cussing enough getting the old gasket off the first time..
