So actually I had four sets. Two on 80 series and two on 200 series. I sold one of the 80’s to @spazzyfry123 and I think he has had good luck. The set on my other 80 had a leaking shock that had to be replaced after a couple thousand miles. Those shocks were replaced with King’s. The first set I had on a 200 series had two different shocks start leaking and required warranty replacement. I only had that one for about 10,000 miles before I sold and got a 2020. Installed BP51’s on the 2020 and did not have any issues other than some squeaks that the next owner sorted out I think. I had that truck for about 13,000 miles with BP51’s. The new truck is the subject of this thread and it has the Dobinson MRR. They are very stout and like them a lot. Holding one of each, the Dobinson seem like better quality but that’s just my opinion.
I also have King’s on my 80 series and have ordered another set of King’s for my 79 series.
Mine (OME BP-51) have been holding up well. I do have my grievances, but minimal in comparison to benefit. Keep in mind mine are on an 80 and different in overall construction to that of a 200.
I like the adjustability factor, but I am quite frankly lazy and the feature is lost on me out of the sheer difficulty to actually adjust. Each time will require a proprietary wrench, strap wrench, strength, and a roll in the dirt.
The ride is great once you get it dialed. I've noticed relatively minimal swings in weight result in the requirement to adjust, however. I have a drawer system that will vary from effectively empty to adding a couple hundred pounds of tools and camp gear.
I am also running OME springs that may be adding to some of my questionable ride quality - but let's get real; I'm in a rapidly-approaching 30 year old farm truck on solid axles and 315 mud terrain E-rated tires. MUCH of this will be lost on a 200 between its coilover design and independent front suspension.
Overall, BP-51 has a proven track record here on the forums for the 200 community and I don't think anyone should be reading too far between the lines to determine an extreme such as not purchasing a vehicle because it has them and a neck beard built a spreadsheet saying so. They're significantly better than stock and the 99% would be ecstatic to have them.
That said, I may be beating up @jomelo to score me a set of these Dobinsons for my wife's 200. Pimp levels are high.
