Dobinson MRR help
tn
Need some help from you pros.
Truck is:
2021 Heritage 3 row
Dobinson MMR front and rear
Front spring C59-542
Rear spring C59-559V
Slee LX slider steps
ARB roof rack
275/70/18 grabber atx SL rated
I have the low speed compression all the way up and rebound all the way up. Rebound all the way up. High speed at 8/10. Ride is compliant in a straight line. But I feel like I’m still getting too much lean and not enough damping in turns. Could it be the soft tires, or maybe I need to increase the pressure in the reservoirs?
Any help is appreciated.
Truck is:
2021 Heritage 3 row
ARB roof rack
By all the way up, do you mean that Rebound is at its fastest setting? Low speed compression is turned all the way in?
All the way up, meaning turned all the way in. So rebound and compression should be very damped/slow
