Do all 470’s have transmission cooler? (1 Viewer)
Oregon
I’m not sure I do...original dealer-sticker doesn’t reference it nor a “tow package“ (although I have a factory hitch and 7-pin connector).
When I look at the radiator from in front of the vehicle, I see what I think is the oil cooler on the left side of the radiator, but I don’t see anything that seems to be a tranny cooler. I think I read it should be on the right side...
Did all 470’s receive a transmission cooler, or is that part of a special package?
Thanks
Pictures would help but my understanding is every single gx 470 has a transmission cooler. If you face your engine bay and open your hood it’s behind where the grill would be right in front of the radiator.
Thanks. Looked in the dark, after getting back from a towing event.
Will look today...
Easiest way to tell is pop the hood, and just under the white coolant reservoir is a small black hose with a clamp. if you see that then its equipped with a trans cooler.
This isnt the gx engine bay but this is exactly what you're looking for.
My brother moved his horns and installed an 80 series LC cooler in the OEM spot. Tight fit, but works well.
