DIY Skid Plates
wenatchee, WA
Anyone made their own skid plates? I’ve got some 1/4” scrap laying around. Getting a wild hair to make my own… just worried the 1/4” is pretty beefy/heavy for the cheesy OEM bolts.
Also worried about promoting rust if I don’t seal the connections properly.
Let’s see what ya got!!
That does seem like it would be heavy. I have a Desert Eagle Offroad cat protection plate that I believe is 3/16" steel and it is heavy as hell! Then again if it going to be used truly for sliding over stuff, not just cat protection, 1/4" might be better/stronger.
Other companies I have seen offer their steel plates in 1/4" aluminum as on option.
I've always thought an old big street sign would be great to make a skid plate/cat protection plate.
Those stock bolts are pretty flimsy looking and small for the weight of 1/4”
I’ve thought that too about a street sign 😂
Been loosing too many hours of sleep thinking of this build. Finally got some cardboard to start mocking it up!! Woohoo!!
You defiantly can DIY if you have all the proper tools.
Our 200 series front ends are very similar to your Tundra. I designed mine but had a shop cut out the parts.
20191014_194036-jpg.2907350
20201210_184511-jpg.2907351
20191015_065515-jpg.2108132
20191017_175423-jpg.2110699
Dude! Thank you for the
Dude!! Thank you for the information & pictures. These help keep the creative juices flowing! That’s awesome!
It may be a moot point, but my intention is to provide a little more protection to this area here:
Yes, I'm using these:
Kind of hard to make a hex hole by hand, so you can use these:
If using the round ones, I would recommend getting them with a "wedge head". They have little teeth on the head that dig into the base metal, which help them not spin. part number example: AELS8-420-260W (1/4-20 thread with max material thickness .260", wedge head)
I got some time under the truck tonight to work on mocking up the skid plates. I’m pretty stoked with how this is going to look!
If you need ¼" steel plate under your truck, you must be planning to drive like a f'n retard. That is way overkill on anything other than a dedicated crawler.
Well, I don’t plan on driving like a retard. I know it’s overkill. I’m not even 100% sure if it’s really 1/4” - might be 1/8” now that I think about it. I haven’t officially measured it. But regardless. I know it’s over kill. I plan on drilling a lot of holes to lighten it up as much as possible.
