A couple of pics of my weekend project :
I am hoping to solve the driveline slack and improve fuel economy at the same time, being about as cheap as it gets I decided I'd try the DIY way.
I used the lockouts from an LJ70 which fit perfectly on my 1990 front axle with short birfield, and welded the rear planetary of the center diff to the rear diff case, and removed the satellite gears.
I cut a thick pipe into a crown shape to weld on the rear planetary, with a 1/4" plate on top of that which welds to the bigger, thickest part of the carrier with preheating and slow cooling, then another bit of pipe ontop of that which prevents the front planetary from walking out of position.
The driveline slack is obviously, the fuel economy I'll report back after a couple of tanks. Return on investment should be OK since I'm just out of a bit of scrap steel, gear oil, electricity for the welder, oven, drill press, grinder and lift, cutting disc, FIPG, argon and filler rods for the welding... Maybe $20 all said and done. I don't value my time much and was too cheap to buy marks4WD kit without having first hand experience on the fuel economy issue anyway.
So far the difference in acceleration and power is hard to tell, but engine and driveline braking seem to be reduced a fair bit. time will tell.
