DIY iPod Integration Install 2002 Lexus LX 470 w/ Factory Nav (1 Viewer)
Ann Arbor, MI
Since my 2002 LX 470 w/ factory nav and integrated climate controls didn’t come with factory iPod integration (no cars did in 2002 I assume), I wanted to add it to this car’s stereo. I also wanted to be able to hide the iPod itself in the lower part of the center console so that it was out of sight but still accessible. After heavy research, I determined what I needed in order to accomplish this (while maintaining maximum sound quality) was the USA SPEC iPod Adapter.
This module allows you to add an input source to the factory head unit by way of the CD changer. The nice thing is you don’t have to remove your CD changer or anything, plus you can use the factory head unit’s controls to change the song while using the iPod source. You can also switch between head unit mode and manual mode in case you’d like to just use the buttons on the iPod like you normally would. The only downside I have found so far is that no iPod text information displays, so you can’t see the song title, artist, playlist name, or anything like that, but I was ok with that compromise.
One other thing you will need to make the USA SPEC iPod Adapter work is the corresponding CAS-LEX Adapter harness. I bought both items from Crutchfield and when I added the iPod module to my cart, it told me I would need the special adapter harness too. Thanks Crutchfield! As I’ll explain later, you simply remove the factory harness from the factory head unit, plug in the CAS-LEX adapter to the factory head unit, and then plug the factory harness into the CAS-LEX adapter.
USA SPEC PA15-TOY ($150): http://www.crutchfield.com/p_581PA1...terface-for-Toyota-Scion-Lexus-and-Isuzu.html
USA Spec Lexus Adapter ($30.00): http://www.crutchfield.com/p_581CASLEX/USA-Spec-Lexus-Adapter.html
I AM NOT A CERTIFIED AUTO MECHANIC, TECHNICIAN, OR ELECTRICAL EXPERT. PROCEED AT YOUR OWN RISK.
Preparation
1) Remove the wood trim bezel that surrounds the head unit. I put a rag over a flathead screwdriver. Try and pry the bezel from the four points highlighted with arrows in the photo. That’s where the retaining clips hold it in. Mine was stubborn, but not too hard.
2) In order to fully remove the trim, I believe there is a wiring harness you’ll also need to disconnect from it that supplies wiring for some other buttons like the power antenna and ext. thermometer.
3) Remove the piece below the head unit that houses the ash tray, cigarette lighter, and 12v plug. Again, pop it out where I placed the arrows. You may be able to remove the trim piece without disconnecting the two wiring harnesses since they may be adhered together. You’ll have plenty of room.
4) Remove the trim that surrounds the shifter, again by popping it out. I was able to leave the shift knob on. Be sure to other things you have to do is disconnect the wiring harnesses for the heated seats, PWR and 2ND drive buttons, etc.
5) Remove the four phillips head screws indicated by the arrows and slowly pull the head unit out. I placed a cloth on my shift knob and was able to balance/rest the head unit on that due to the tension of the wiring harnesses (that we won’t be messing with here).
iPod Module Install
1) Remove the factory wiring harness on the left side (if you’re looking at the rear of the head unit) and replace it with the CAS-LEX adapter as shown in the photo. Then, plug the CAS-TYi cable into its corresponding opening of the CAS-LEX adapter, followed by plugging factory harness into the other corresponding opening.
2) Decide where you want to place/mount the iPod Module. I placed mine in the space underneath where the cupholders are. I wanted a flat space that would be relatively easy to run cables to, but also in a place where I saw a way to fasten it.
3) IMPORTANT — DIP Switch setting on iPod module. Per the instructions that came with the iPod module, set the DIP switch accordingly. I honestly can’t remember how I set mine, I should have written it down, but be sure to test the unit before go any further to make sure it works as it’s supposed to so you don’t have to tear the front apart again. Meaning, when you select disc 5, it puts the iPod in Direct mode and when you select Disc 6, it puts the iPod in Manual mode. I can’t remember if the "1" switch stays down or you need to move it up, but follow the options the instructions give you in case the designated option according to the provided chart doesn’t get it to work.
4) Run the CAS-TYi cable behind where the head unit resides, down behind the sections below the head unit, and underneath into the area below where the shifter trim panel resides. Connect the CAS-TYi to the iPod module.
5) If you’re going to place your iPod in the lower part of the center console like me, then you’ll need to drill a hole big enough to fit the one end of the CB-PA105 cable (that connects the iPod to the iPod module. I believe I used a 1/2 inch drill bit and attacked the lower console from the side of the cup holders. It was kind of a pain to get good leverage, but it’s possible.
6) Run your CB-PA105 cable through the hole you just made in the lower center console to make sure it fits and then connect the end that goes into the iPod adapter.
7) Now that you’ve got your iPod module module in place and your wires and adapter harness connect, clean up and mess you made. In my case it was vacuuming out plastic from the drilling process as well as all of the crap accumulated and left behind by the previous owner.
8) Fasten the iPod module some how to reduce future movement and rattling that could cause either of the connected cables to become dislodged or damaged. I zip tied mine to some metal brackets that lay underneath where the cupholder section goes.
9) Replace the trim panels for the shifter console and then tuck the wiring connected to the back of the head unit neatly behind it so when you screw the head unit back in there’s no tension or risk of anything coming loose, not to mention it fits flush the the trim bezel fits properly back over it. Don’t forget the harness that goes back into that wood trim bezel either.
Nice write up Bludy. Is there an adapter available for the newer Lightning connector instead of the old 30 pin?
How would you rate the sound quality?
The sound quality is very good. You can definitely hear some signal noise if the volume is loud, but depending on the kind of music, you don't notice it as much. Meaning, the more instrument tracks there are in a given song, the less noticeable the signal noise is, but again, only when the volume is cranked.
I have both the USA SPEC PA15-TOY (iPod) and BT35-TOY (Bluetooth), and after I installed the Bluetooth module I tested it's wireless Bluetooth streaming from my iPhone. The sound quality was garbage. As I have read in several other places on here, the music streaming from the BT35 is OK, and it's convenient to be able to do it directly from your phone, but there's no bass for some reason.
As an audiophile, I'd like to think my standards are pretty high when it comes to sound quality, so hearing the full dynamic range is a must for me, especially because I added an aftermarket amplifier and subwoofer (bypassing the Mark Levinson factory sub). The USA SPEC PA15-TOY iPod integration module does the job.
I was ready to jump on this when I first saw it here on MUD, but then Apple changed over to the lightning plug and so did our devices. Thought USA SPEC would have updated their product by now that it's been a while, hmm. Too bad on the bluetooth integration quality.
I use the VaisTech on my 2006 and I think lightning is supported on that one. Otherwise, basically same install. I'm not using the cable, just Bluetooth (the unit supports both cable and bluetooth streaming profile) from the phone because I knew I was going to change phones soon when it was done. I've never gone back to the cable...
Mine was very good. Better than the new Bluetooth model I just got. At least for sound. But the cable went bad. It did last 2 years though. I had it tucked in the 4wd shift leather.
I have the USA SPEC PA15-TOY (iPod) also. Took advantage of the RCA jacks on the module and added RCA to 1/8" stereo jack. You give up a couple ipod control features IIRC but the trade off is nice to have both 30pin apple and 1/8" stereo jacks.
OK, apparently this cable setup won't work on my 04 LC with nav. Unless Crutchfield fitment guide is wrong.
USA Spec iPod® Interface for Toyota, Scion, Lexus, and Isuzu
Anyone have any advice? All I want is an Aux cable from the factory cd changer to an ipod/iphone. I don't want bluetooth because I want to retain the factory bt connectivity for phone calls.
Not seeing it will not work-
This interface connects a compatible iPod/iPhone to select 1997-2013 Toyota, Lexus, Scion, and Isuzu audio systems. Its on-board software translates commands from your factory radio's CD-changer controls into commands the iPod/iPhone understands. This interface allows you to retain CD changer, Rear Seat Entertainment/DVD, and Satellite Radio - while providing the following iPod/iPhone functions through your vehicle's factory radio:
Their site claims my year is incompatible.
When you say you want an "Aux cable from the factory cd changer to ipod/iphone", do you mean you want to use the CD source as the source for your ipod/iphone?
By "Aux cable", do you mean you want to use the additional RCA output on the USA SPEC module instead of the ipod cable?
Are you using the CAS-LEX harness or CAS-TLC harness instead of the adapter harness that came with it?
Have you tried alternate DIP switch settings? Especially since it doesn't give you what to switch the #1 position to?
You may want to take a look at www.vaistech.com . They have a fairly detailed fitment guide on their site under FAQ/General Questions. I have no personal experience with their directly connected (USB/iDevice) products. I went with their Bluetooth device (SL3B) in a 2006 LX and have been pretty pleased with the results. In my vehicle, it hasn't seemed to have had any impact on the factory bluetooth phone connectivity (the phone sees them as 2 different devices with 2 different profiles).
If possible, yes.
If I can do it without removing the CD changer, that's fine too. But what input would I use? I thought I had to use the changer input.
Yea, you hit the CD button on the head unit, and then press disc 5. Then you need to make sure the DIP switches are in the appropriate position.
I know that Crutchfield says nothing is compatible with your 04 Land Cruiser, but it might be worth a shot trying to use either the CAS-LEX or CAS-TLC adapter harnesses.
Thank you
Thank you
Maxse01, I too have an '04 LC with Nav and BT (and rear dvd player). I'm looking to do same thing but really don't care if it's a Bluetooth, 3.5" aux in or a 30-pin/lightning option.
My rear overhead DVD player has a DVD stuck in it and I never used it anyway so I'd like to remove that input from the audio system and use it for the ipod/phone input if able.
Anyone had any experience doing this? Anyone found a successful, good-sounding and relatively simple method for doing what I'm looking for with an '04 LC like mine?
Crutchfield no longer has the USA Spec Lexus Adapter PA15-TOY but Amazon sells them. Hoping someone can help me - I have a 2002 LC and want to use an older IPod for satellite radio and music that is on the iPod. Do I need anything else besides the PA15-Toy to make this happen? My current setup for satellite radio uses a skydock so would need to be able to plug an aux cable into the skydock for Sirrius radio.
Thanks,
Jeff
