DIY Channel Strut Roof Rack
Super77
Seattle
Quick feeler since I’m certainly not the first to think of this:
I want to be able to use channel strut (aka Super Strut or Unistrut) with the stock roof rack rails.
This stuff:
Why?
- The factory rails are decent but the cross bars are poor design. They’re flimsy and aggressively crowned. Hard to keep things flat.
- Aftermarket roof platform systems are expensive and overkill for me. I’m not doing a full gear loadout with every trip, mostly likely I’m using it for a Home Depot run or 2-3x/yr with my rooftop tent
- I want something flexible and adaptable that I can modify with off-the-shelf hardware.
- Factory-rail crossbars are one option. They range from $80 to $200 each. They’re ok if you’re using two, but anything more and you start to deal with the crown on the factory rails.
- The channel strut universe is huge and relatively cheap. It’s a commodity product, available in different sizes, materials, and finishes. With the right combination of hardware, you can get a pretty professional-looking outcome.
- Channel strut cost-per-foot is around the same as the lower end of commercial crossbars, but with added flexibility.
So one problem to consider is interface to the factory roof rails: somewhere along the way you have to adapt a curved rail to a flat plane. How do you securely and aesthetically join the two?
Has anyone seen this done successfully, with great fit and finish? My goal is a mostly DIY 3 or 4 crossbar, factory rail-installed system, perfectly flat, for under $300.
This is a nice alternative DIY approach. It does require stripping down to the bare roof, but if the pricing hasn’t crept up too much, might get me to my goal.
Interested in more ideas like this.
Gamiviti has options on their website. I looked into this a while back. I know for sure there's one for 80/20 aluminum extrusions.
Edit: Gamiviti stock rail wing bracket
Oh, that’s a nice low cost solution that keeps the rails but improves on the s***ty crossbars! Looks like $35 a pair, so a triple crossbar setup with 1x2 black aluminum T-rail and hardware gets me right near my $300 budget.
Now if @nakman can confirm that these are height-tweakable by a few mm so that all 3 make a flat plane (by canceling out the roof rails’ camber) this solution would be perfect 😉
Thanks for the tip!
