DIY Carpet Install
salt lake city
I have been meaning for a while to get a thread up for how I did my carpet and show some pictures of the process. I will preface this thread by saying there are precut kits available which I'm sure are great, but this is a cheaper option for those not looking to spend 500-1000 dollars. Our intention is to wheel the rig hard, its our fishing and camping rig and show room floor quality carpet was not the number one priority. The selected materials are affordable, are easy to install yourself and I feel it looks great. We use weather tech mats to alleviate unnecessary wear on the carpet.
So to begin obviously we need to gut the interior. Remove all your seats, the console, etc. Now is a good time to order the plastic push connector things that hold the interior together, you're going to break them anyway so just take care to not damage the panels. Most of it should just pull out by hand. I use these ones when going back together.
They are slightly bigger than factory but hold very tight and prevent the interior from rattling at all.
The carpet shouldnt be too much of a challenge to get out. If you rig is how mine was youll find about 15 dollars in spare change and a dozen hairties under the carpet.
The next few steps are going to be optional but I will how anyway.
You will need to remove the rear heat unit as well, theres decent write ups on that already so Ill spare you the reading. I elected to completely remove the rear heat option. I ground off the mounting studs for the unit and welded in a piece of steel over the hole. Its a good idea to use seam sealer on the bottom after your welding is complete and paint everything to prevent rust. Delta also sells a plug for this hole if youre not able to weld sheet metal. The welding here looks like crud, at the time I had a harbor freight machine, but it will do. You can sand it smooth if you like.
Next I removed all the plastic plugs from the tub and set them aside to reinstall later. I wanted to install new sound deadening material and purchased two boxes of Kilmat. I purchased this pack, although it is currently unavailable. Similar options are out there and will substitute fine.
The factory rubber in my rig was hard as a rock and a lot of it could be removed just by hitting it with a hammer, using a gasket scraper or a wire wheel on a 4 inch grinder. I welt over everything with the wire wheel while trying not to remove the factory paint/primer. Now is the time to repair any other rust you find. I had a big rust hole in the right rear wheel well and rust where you would put your left foot in the drivers footwell. Unfortunately this is another time when the right way to do it is to cut out all the cancer and weld in new material.
Pay special attention to the rear seat mounts and middle row seat belt mounts on the wheel well. My left seat belt mount was rusted out and was also repaired. Once all the repairs were made I sanded the entire tub with 220 sand paper, mostly by hand since the tub has so many variations its pretty tough to do with a sander. I went over all the repairs I made and the foot well areas with a sandable primer and also prepped it.
I dont have pictures of the tub after prepping but I had to get it completely clean in preparation for the next steps.
Mostly prepped and ready to shoot. For the tub I used black raptor liner and shot it thru a HVLP paint gun, to do so you need to reduce the product by 20% with urethane reducer. I used my old hood to get the spray pattern and air pressure correct. Doing it this way results in a much finer texture than the supplied gun in the raptor liner kit. At this time I also shot the tail gate and the grill.
It is a bit of a pain to use a hvlp on a horizontal surface, just dont fill the gun too much so it doesnt drip out of the cap or the vent and youll be alright. I let the raptor sit for a full weak before moving on.
I will follow up with a reply as I can not attach anymore pictures to this one.
So after I let that dry completely I reinstalled the plastic plugs into the tub. I didnt bother sealing them or anything, I think they fit tight enough. Next I applies the Kilmat insulation. I used a vinyl roller I found in the flooring section at lowes for a lot of it. Its good to have a second set of hands for this as once you stick it, its not adjustable. I cut the material with a razor and sometimes scissors. Just lay out yout material before had to cover as much as you can without excessive overlaps.
I didnt go out of my way to cover every bit of the tub as you can see. When you are done laying it all out you need to roll it unit all the bubble texture is out of the material.
So now the fun part. Youre going to need some sort of padding and the carpet. I purchased my jute and carpet from Albrights supply
This is the carpet I used, It is very stretchy and forgiving, just be careful as once you stretch it a certain amount it will not shirnk back to its original size.
This is the jute I used
As you can see the material is pretty darn affordable. I had about 3 yards of carpet left over as I wanted it to cover my sleeping platform/drawers that went in the back. I think you could get away with ordering 3 yards but I recommend 4 just in case you mess up and need to restart on the front.
You are going to need about 4 cans of spray adhesive. I used 3M 90
Spray adhesive (hey look I figured out how to do hyperlinks, der)
Lay your jute out and butt the edges up in the center of the tub. Dont glue anything yet. With a good pair of scissors and carpet razor blades begin to cut out the shapes of the shifts, Ebrake, console mounts, and rear heater mount if you intend to reinstall it. I also cut about one inch squares out of the jut around each of the seat mounting holes, just to make them easier to find after the carpet is in. Have your console and shifter cover ready so you can test fit everything. Work out all the wrinkles you can and if you have excess material or if it bunches up due to the transmission tunnel, direct the excess to go under the seats, it will be our secret. Cut holes and route your seat wiring, rear heater wiring, etc thru the holes. DO NOT trim the outside edges yet, as you install the jute it will stretch and move and you dont want to not have enough if you cut it too close before installing.
Its a bit like wrapping a present, get it all to contour to the tub. Once your happy with your placement, from the rear, roll up your jute towards the front. I used a tiny bit of duct tape at the front to mark where the beginning edge should go.
Again this is a task thats best with two people. Shake the adhesive well and when youre ready spray both the tub and the jute and let it get tacky ( about 10-15 seconds) I did about 4-6 inch strips of adhesive at a time. Once you set it down use your carpet roller and the butt off your palm to get a good adhesions and rub the jute into all the contours. Repeat this procedure until all the jute is in place.
Once your Jute is glued entirely you can carefully cut the edges flush with the sheet metal at the doors.
Next we will do the same thing with the carpeting. This is the moment of truth. Lay your carpet in the tub and push a bunch of excess in a big lump in front of the shifter. I left probably a whole yard extra in front of the shifter. With your scissors cut a hole in the carpet where the shifter will go. At this point you want to go as small as you can, just enough to get the carpet over the shifter. This will set our center point and everything else will be us working out and away from the shifter.
With all that excess in the front, cut a line going down the center of the carpet and pull the two pieces into the driver and passenger foot well. This is a time consuming process but again we want to work the carpet into all the contours of the tub. Make cuts where necessary to fit around the Ebrake, console mounts, etc. Test fit your plastic interior pieces frequently. Just go slow and avoid cutting more than is necessary. Its better to make a small slit and stretch the carpet around the different parts of the interior. This time around it is necessary to spray and glue and place the carpet all at the same time. Start at the front and work slowly. The carpet will stretch a lot more than you think, If you end up with excess, again push it to where it will be under the seats and out of sight. Make sure the carpet goes as far up the tub as you can get it, closer to the firewall the better. Pay attention to the area around the gas pedal and make sure the carpet lays in there nice and snug to the tub to avoid interference with the throttle.
The only pictures I have at this point are in the middle of the install. Keep working the material and it will look less bumpy than it is in these pictures.
When you are happy with everything and all of it is glued in, get a large phillips screwdriver you dont care about. Youll also need a torch or a heat gun. Use your fingers and find all seat mounting holes and any of the other bolt holes you intend to use again. Heat your screwdriver up and poke it thru the carpet and work it around the bolt hole a little bit. This will open your bolt holes up and prevent the carpet from get snagged on the bolts and getting twisted up. Its like melting the end of a rope so it doesnt fray. Really thats all there is to it! I think we did the jute and carpet in about 8 hours. Just be cautious, cut small amounts at a time and test the fitting of the carpet a lot before you add any glue and it will look great. I will get some pictures of our carpet now that its been like 6 months this evening and upload.
Thanks for putting this write up together! This is amazing!
qq though, what are you grounding to the tub in the picture with the acetone? Was that just for welding?
